Configure an ACE IP protocol
Configure ACE IP protocol entries to have the filter look for packets of specific protocols.
  • The ACL exists.
  • The ACE exists.
  1. In the navigation pane, expand Configuration > Security > Data Path.
  2. Select Advanced Filters (ACE/ACLs).
  3. Select the ACL tab.
  4. Select the appropriate ACL.
  5. Select ACE.
  6. Select the appropriate ACE.
  7. Select IP.
  8. Select the Protocol tab.
  9. Select Insert.
  10. Specify the operation type.
  11. In the List box, enter the IP protocol type.
  12. Select Insert.
Protocol Field Descriptions
Use the data in the following table to use the Protocol tab.
Name
Description
AclId
Specifies the ACL ID.
AceId
Specifies the ACE ID.
Oper
The eq parameter specifies an operator for a field match condition: equal to.
List
Specifies the IP protocol type. Entries include 0–256, undefined, tcp, udp, ipsecesp, vrrp, and undefined.
